Didn't know the graphiics were stickys!
RE: Didn't know the graphiics were stickys!
And what about your tank, good sir?
I just wish one of two things...
I just wish they didn't clear over the decals on the tank OR
People would stop wadding up bikes so my cheap *** wouldn't end up buying them and fixing them up.
It'd be such a breeze if you could simply remove the decals from the tank but no, you have to sand them. Down to metal in most cases - not the entire tank but that is also another PITA because you have to be mindfull of your sanding so as to feather everything together without humps in the finish and such.
A shop-quality heat gun is your friend. Seriously. It will take all of 3 minutes per decal to remove them perfectly. Wipe down the residue (what little there will be) with Goo-Gone and you're golden.
I think a quality heat gun will run you about $30 - which is a killer investment in all honesty. You'd be surprised as to howoften you might need it!
ORIGINAL: KidCr3nshaw
