cooling problems
Old May 16, 2007 | 09:41 AM
kkevin_g1's Avatar
Default cooling problems
any idea on a cooling issues. fan works, thermostst works, no clogs in radiator, every thing seems to be circulating fine, however ill ride for 20 min and water in the resvoeir. any ideas pls help
Old May 16, 2007 | 09:54 AM
gerharddvs's Avatar
Default RE: cooling problems
If your temperature isn't very high when the water pushes out you should check your radiator cap. If that spring valve isn't working properly water will push out all the time. It's only suppose to push out water when the radiator is very hot.
Old May 16, 2007 | 09:58 AM
gerharddvs's Avatar
Oh yes if when U refer to the reservoir and U mean the water tank in the frame... That should always have water/coolant in it.You'll see it's got a min and max level.(as long as it doesn't overflow)
txoutlaw04
Jun 17, 2010 04:04 PM
babyblade400
Jul 18, 2009 08:30 AM
kdub41
Jul 10, 2008 10:45 PM
jonz7828
Oct 16, 2007 09:19 PM
Bran Bel
Sep 13, 2007 07:03 PM
