clutch wire
Old Mar 6, 2006 | 03:05 AM
cbr_newbie's Avatar
Default clutch wire
i put in a new clutch wire but when ever i fully ingage my clutch lever it still has grab on the clutch, whats up wit that?
Old Mar 6, 2006 | 03:14 AM
cbr_newbie's Avatar
Default RE: clutch wire
o yea, and im thinking about makin custom t-shirts anyone intrested in buying any?
this will be on the front undecided what i want on the back.. this is just thoughts though not sure if im going to actually make it or not
Old Mar 6, 2006 | 03:50 AM
Downforce137's Avatar
you mean with the lever all the way in, the bike still trys to roll?? sounds to me like its not adjusted right.. there should be about 1/8th inch play in the lever before it even pulls the cable at all.. But I think in your case, the cable needs to be tightened a bit.. in other words, back the adjuster on the lever perch out a bit..
If you have the bike on a rear stand, running and put it in gear, the wheel is going to turn, no matter how you have the clutch adjusted.. But if im reading correctly it sounds like the bike want to go in gear with the clutch in.. correct me if im wrong..
Old Mar 6, 2006 | 10:45 AM
cbr_newbie's Avatar
no i dont even my bike running lol, when i try to turn the motor over with the bike in gear it will want to move forward, it didnt used to do that it used to stay sit like a good puppy, and i have no freeplay at all on my clutch wire thats what is wierd... i'm gonna go up to my local bike shop after i get it running and ask them to help me with it
Old Mar 6, 2006 | 04:00 PM
welp, if the bike is in gear, and you are trying to turn the motor over, it will try to roll forward usually.. mine does it too.. If theres no freeplay in your lever, you need to turn the adjuster on the perch in, until you get the desired 1/8" inch play.
Old Mar 6, 2006 | 08:30 PM
cbr_newbie's Avatar
herm.. well the clutch wire i had before this i let in the clutch and it wouldnt try to lerch forward while in gear... and now i cant move my bike by putting in the clutch unless i shift it in neutral.. wierd.. i'll go to the b ike shop later this week
redzintimidator
How-To: Mechanical
174
Aug 8, 2014 01:07 PM
Zandaloo
Aug 22, 2013 03:26 PM
Optimus_Prime
Apr 24, 2012 02:16 PM
aight
May 1, 2011 02:05 PM
riclyd
Jul 19, 2010 12:45 PM
