clutch springs
Old Feb 7, 2008 | 05:27 PM
buddah's Avatar
Default clutch springs
so I got some new clutch springs from barnett----everyone says to stick with the OEM clutch plates----should I replace anything else while I'm in there? or do you think that the springs and new OEM clutch plates will do the trick? I haven't had any clutch problems but the bike is a little older so I figured it wouldn't hurt to do this.
Old Feb 7, 2008 | 05:59 PM
pacemaker's Avatar
Default RE: clutch springs
If it ain't broke, then why worry about it. You can really open up a can of worms here & end up with a clutch problems.
Old Feb 7, 2008 | 07:44 PM
buddah's Avatar
yeah you are right I'll probably just hold on to em until I need them
Old Apr 23, 2008 | 05:20 PM
jahnaboi's Avatar
Buddah, how much and where did youg et your clutch springs?
Old Apr 23, 2008 | 05:45 PM
KidCr3nshaw's Avatar
The difference you'll notice is that next time you change your clutch, you won't need to replace the springs.
They're just stronger springs is all. Check yours with a caliper and if they're in spec, consider the amount of miles they have on them - if that suits you fine then replace them with the less expensive OEM springs.
Weird... not often OEM is cheaper
cBrentb
Mar 10, 2014 07:36 PM
stefan2m
Jun 1, 2011 09:49 PM
Shadow
CBR1000F For Sale / Found
Nov 28, 2009 09:30 AM
F4i
Aug 22, 2009 06:51 PM
Chippy211
May 2, 2009 05:53 AM
