Clutch lever removal
I've looked around, but the bolt that holds lever on is stuck. The bolt for the lever not the mount. I read around that there is a nut underneath but mine does not have one. I'm just wondering if anyone has a technique to remove this stuck bolt?
Hey Swaggard,
The hole in the bottom of the perch is threaded. The pivot bolt actually threads into the bottom of the perch, then a jam nut is threaded to the pivot bolt to prevent it from turning out from working the lever. Sounds like the thread in the perch or on the pivot bolt are stripped?
Put a flat blade screwdriver under the pivot bolt head to pry upwards, while you turn the bolt with a wrench or socket.
Hope that works out for you. Good luck.
