Clutch lever removal
Old 05-04-2012 | 11:22 AM
swaggard's Avatar
Default Clutch lever removal
I've looked around, but the bolt that holds lever on is stuck. The bolt for the lever not the mount. I read around that there is a nut underneath but mine does not have one. I'm just wondering if anyone has a technique to remove this stuck bolt?
Old 05-04-2012 | 07:06 PM
Shueisha's Avatar
Stuck bolts I normally coat in WD40 and leave it overnight. Depends on how old the bolt is but it normally free's it up.
Hope it helps
Old 05-05-2012 | 08:00 AM
Burnt Dragon's Avatar
Hey Swaggard,
The hole in the bottom of the perch is threaded. The pivot bolt actually threads into the bottom of the perch, then a jam nut is threaded to the pivot bolt to prevent it from turning out from working the lever. Sounds like the thread in the perch or on the pivot bolt are stripped?
Put a flat blade screwdriver under the pivot bolt head to pry upwards, while you turn the bolt with a wrench or socket.
Hope that works out for you. Good luck.
coolcloo
05-09-2011 09:12 AM
Quick Reply: Clutch lever removal
