clutch install need help ASAP.....
Old Mar 11, 2008 | 07:56 PM
dougcrx's Avatar
Default clutch install need help ASAP.....
i just did my clutch but with no avail i out the cover back on and the is nothing in the clutch lever.....i went back through....everything was put back where it was...i replaced the springs and friction plates......but there is nothing there...i had to adjust the cable all the way just to get something at the lever.....but the clutch isn even engaging...the drive sprocket still turns when the lever is released.....im lost
Old Mar 11, 2008 | 08:03 PM
Sproutf3's Avatar
Registered Users
Default RE: clutch install need help ASAP.....
Maybe because i had a similar problem. When you pull the clutch, the cable pulls an arm with a spring, the springlever turns a rod which pushes a large pin inside of the clutch cover. When i was playing with it this system got a little fubar, and it took a few minutes to figure out how to put it back in right play with the arm and make sure the pin is moving out ward, you'll have to push it back in by hand as the clutch is the return pressure for it in the engine.
Old Mar 11, 2008 | 08:10 PM
SIRR1's Avatar
It sounds like the clutch arm is not alligned right.
Did you ingage the clutch arm on to the push rod when installing the side cover?
If you did not you will have no clutch.
When installing the right side cover or clutch cover you have to move the clutch arm back and then forward as the cover seats into place.
Or you did not install the clutch push rod, either way the side cover needs to come off again!
Old Mar 11, 2008 | 08:15 PM
dougcrx's Avatar
im about to go out there and mess with it...i thought that might be it....it seems to be misaligned but i couldnt tell whether it was wrong.....
Old Mar 11, 2008 | 08:19 PM
dougcrx's Avatar
everything seems right....my clutch cable is frayed at the end and may have snapped when i engaged it the first time.....ugh......
Old Mar 11, 2008 | 09:09 PM
KidCr3nshaw's Avatar
First, replace your clutch cable.
If that doesn't work then I bet I know the problem. When I replaced mine, it did the same thing except my cable was fine.
Turns out there is an alignment notch on the clutch basket, it needs to be alligned with the clutch housing notch. It's in your manual, but it's easy to overlook.
If you have used the alignment marks and I'm only telling you what you already know then ignore me...
Old Mar 12, 2008 | 11:12 AM
dougcrx's Avatar
well im going to replace the cable first.....but i thought i aligned the punch marks like the manual said.....the stamped circles with the diagonal line through them?.....would those be the punch marks?.....
Old Mar 13, 2008 | 08:34 PM
dougcrx's Avatar
well i ordered a clutch cable because im almost positive thats the problem....everything was assembled correctly and the clutch is functional just not by the lever....
Old Mar 14, 2008 | 03:54 AM
A frayed cable will most definitely feel like the clutch is jacked.
Old Jan 18, 2012 | 04:26 PM
BHDJ F2's Avatar
I have all
rocklizzard91
Apr 13, 2012 12:31 PM
BHDJ F2
Jan 24, 2012 09:04 PM
tyfishfinder
Mar 9, 2011 12:47 PM
rex4mayor
Jul 23, 2008 11:44 PM
dougcrx
Mar 30, 2008 01:52 AM
