**clutch help asap!**
Old Apr 12, 2012 | 09:36 PM
rocklizzard91's Avatar
Default **clutch help asap!**
hey all, going to the honda parts shop tomorrow morning to order some parts and i need to decide on what parts i need
the clutch is my main concern and im not sure if i just need the springs or if i need the friction discs too.
here are the discs:
do the discs look useable?
i was getting a slipping clutch at high rpm, and i had to adjust the clutch cable all the way out so that it would grab. so im not sure if its the 4 springs or if its the discs.
it looks like the first and last ones are the same disc, and the middle 4 are all the same. correct?
anything else i would need while doing this clutch job?
i would really appreciate quick responses so i can still go tomorrow before class!
Old Apr 13, 2012 | 09:50 AM
sandrailman's Avatar
you need to check the friction plates with a micrometer and make sure they're within the tolerances according to the shop manual to see if they're bad
Old Apr 13, 2012 | 12:31 PM
grrr alright. ill have to go out and see if i can borrow a micrometer from the shop here at my campus. mine is back at home :/
thanks!
BHDJ F2
Jan 24, 2012 09:04 PM
dougcrx
Jan 18, 2012 04:26 PM
tyfishfinder
Mar 9, 2011 12:47 PM
alysiak00
Feb 2, 2010 03:06 PM
dougcrx
Mar 30, 2008 01:52 AM
