CCT problems 900
Old Mar 3, 2008 | 04:09 PM
slimmyslim1420's Avatar
Default CCT problems 900
OK I have a 97 900rr. I try posting there but there is not a whole lot of people on that so I figured I would try here. I got the manual CCT and was trying to install it this past weekend with some other work. I was trying to follow the instructions on the back that said remove the valve cover and push the chain, but that doesn't work. After looking I found a write up on cbrworld of how to do it, and it just basically said by sound. So I put it back together to do it that way and now I can;t get it to start. I cleaned the carbs and changed the sprockets and chain and that is the other work I done. But when I had the valve cover off I turned the motor like the instructions said. Is it possible that caused it not to start? Or is it maybe just cause the carbs are dry? It sounds like it is really trying to start it just won't. But i'm waiting on the battery charge now before I try again. It is the APE manual CCT.
Old Mar 3, 2008 | 04:48 PM
Default RE: CCT problems 900
First off, I don't know anything about the 900 so this is just speculation on my part. If you replaced the CCT and currently there is a lot of slack in the cam chain because you haven't done any adjusting on it yet, then that slack could cause enough change in valve timing that you're not going to be able to get it to start. Is there currently any slack in the cam chain at all ? If you take the right inspection cover off and turn the crankshaft small amounts either CW or CCW, do the cam sprockets turn immediately, or do they hesitate a little before starting to move? If they hesitate, then there is slack and that may be your problem.
Old Mar 3, 2008 | 07:25 PM
ORIGINAL: idodirt
Ok well I got it started. But it didn't have slack in it cause I had it tightened to the point where it wouldn't. The write up I read said turn it snug then back it off a quarter turn. But the write up was for a 600 f3/f4/f4i and since my bike uses the same CCT it works. Theonly difference is the location. But know help figuring out exactly where to set it. Cause there is about a full turn of the bolt where it sounds smooth, so should I go toward the loose side or the tight side?
m21oliver
Oct 1, 2018 10:52 AM
clintthec
Jul 27, 2011 06:04 PM
honda23
Jun 28, 2011 12:24 PM
cr cbr
Nov 28, 2006 04:36 PM
