CBR600FW power problem
Old Jun 30, 2013 | 07:02 AM
WhiteGhost's Avatar
Registered Users
Default CBR600FW power problem
Hi, I have a problem with my cbr600fw which I cannot seem to find a solution for. When I turn the key in the ignition I get no power whatsoever through the bike however when I turn the key to the off position the alarm starts making weird constant chirps. I cannot disarm this unless I turn the key back to the on position or disconnect the battery. Has anyone ever experienced this?
I have just recently (yesterday) replaced the stator and reg/rec but still problem persists.
Here's a video of the problem
Old Jun 30, 2013 | 08:53 AM
Sprock's Avatar
alarm system wiring is messed up imo find the installation diagrams and go through it x2 check everything
All assuming the alarm system controller is good
Old Jun 30, 2013 | 08:58 AM
74demon's Avatar
Check your 30a main fuse. Its probably blown or your battery is dead.
Old Jun 30, 2013 | 09:51 AM
WhiteGhost's Avatar
Registered Users
Thanks for the suggestions. The 30amp main fuse is still in tact (I replaced with the spare just to be sure) and the battery is holding 12.7volts. I guess my only option is to strip back the alarm (which I was hoping I wouldn't have to do). It was installed prior to me buying the bike so have no documentation on it but should be able to find something online. I wouldn't mind getting rid of the alarm completely but I hear it is a nightmare to do as it is wired into the immobiliser
Old Jun 30, 2013 | 02:05 PM
CJardine's Avatar
Track junkie & modaholic
It should not be too hard to remove. Why do you want to remove it? What kind of alarm do you have and ill see if I can find a wiring diagram.
Old Jun 30, 2013 | 02:34 PM
CorruptFile's Avatar
June 2013 ROTM
Does the alarm always sound like that? Is your battery dead?
Old Jun 30, 2013 | 02:49 PM
CJardine's Avatar
Is it in sleep or winter mode?
Old Jul 1, 2013 | 11:47 AM
WhiteGhost's Avatar
Registered Users
Thumbs up
I have managed to find the problem. I traced back through the wiring and found the wire from battery to main fuse had melted half way through. I ran new cable through and all is fine now. The main fuse on second inspection had warped slightly as well so I'm guessing it didn't break like it is supposed to. It seems tat the melted cable was providing too much resistance so bike and alarm weren't getting full power. Thank you to everyone who gave input.
blazinron
Mar 27, 2011 01:44 PM
HKchucksta
Sep 2, 2009 10:29 PM
mixerspike
Jun 2, 2009 09:29 AM
newnut
Sep 26, 2008 09:37 AM
smokin_cbr
Jun 14, 2007 09:01 PM
