Cbr600f3 bad valve clearances
Old Nov 4, 2022 | 03:10 PM
Mikeyv123's Avatar
Default Cbr600f3 bad valve clearances
Hi. I have recently bought a 1998 cbr600f3 with 33000 miles the previous owner has tried to do the valve clearance his self and obviously done something very wrong. It now runs on 3 cylinders and smells like fuel when it’s running. Is it a case of just re doing the valves or is there a chance the valves themselves will now be damaged. I have the option of another engine but if it’s just a case of re doing all the shims then I will just do that. Thanks in advance for any help
Mike
Old Nov 4, 2022 | 06:10 PM
dannoxyz's Avatar
Measure actual valve-clearance in use right now.
The numbers will tell you what needs to be done next
Old Nov 4, 2022 | 09:13 PM
A couple things to add.
when shimming the valves, it’s better to error on the side of loose. The valves will tighten the tolerances over time due to wear.
Adjusting by the valves is the first step In syncing the carbs. That might be the next step
josh123
Oct 8, 2010 07:09 PM
MR2turbo4evr
Jul 20, 2008 03:58 PM
GILL
Feb 17, 2008 08:02 AM
SwashBuckler
May 23, 2007 03:30 AM
suream
Jul 13, 2006 03:47 AM
