CBR F3 fuel pump flooding
Old Feb 18, 2019 | 06:21 PM
You are supposed to adjust each screw, starting with #3 until the RPM no longer increases. Then you back it off by 50 RPM. Then adjust the idle control **** until you read 1,200 again. Then repeat for the other carbs.
Old Feb 18, 2019 | 06:23 PM
TD350's Avatar
I know man! What I'm saying is is that no matter how much I turn out those little bastards the rpm doesn't change!
Old Feb 18, 2019 | 06:37 PM
If you can hear the RPM change then adjusting the screws is working.
Old Feb 18, 2019 | 06:41 PM
TD350's Avatar
... It only changes if I bottom out the pilots.
Old Feb 18, 2019 | 06:48 PM
The change in sound isnt severe no matter what you do. It's really important to have something sensitive to monitor it. I don't know if the induction tach you are using is accurate enough to do that. Like I said before I haven't used the one you have so I can't speak to it.
Old Feb 18, 2019 | 06:52 PM
TD350's Avatar
Ok its not my tach so lets put that to rest.
nickersk
Aug 15, 2018 08:43 PM
Harmless
Jan 23, 2013 01:05 PM
wooferdog
Jan 12, 2011 05:00 AM
mitchedwards81
Nov 25, 2009 05:40 PM
trav9980
Dec 22, 2007 02:16 PM
