CBR f3 engine problems
Old Aug 2, 2007 | 06:48 PM
poorkid's Avatar
Default CBR f3 engine problems
I can't find the cause of a miss at low rpm cruising and 1/4 to 1/2 throttle openings. The miss leaves under full throttle. Any suggestions? All the CV boots are good. I put new plugs in.I installed a Factory Pro jet kit and nothing made a difference. I have a Uni foam filter and aftermarket can.
Old Aug 2, 2007 | 08:06 PM
Jack Riddley's Avatar
Default RE: CBR f3 engine problems
can you give more details? Full throttle suggests jets because it's on the main jet. More details please.
Old Aug 2, 2007 | 09:37 PM
poorkid's Avatar
It wouldn't be the main because the problem goes awaywhen I give it full throttle. Needle changes didn't make a difference. Are there any valves or senloids on the f3 that may affect the jetting? Also what are all the hoses by the air box goingbehind the carbs into some sort of valves?
Old Aug 3, 2007 | 12:42 PM
tgrimaldi87's Avatar
hey poorkid, my bike has the exact same problem. Those hoses are a vacume system which I think the problem might be reading old posts....I am trying to get mine right so I will be following this thread and tell u if I find out
Old Aug 3, 2007 | 03:43 PM
First, what year is your bike? Can you describe the problem in full so we don't make foolish suggestions?
Old Aug 3, 2007 | 04:04 PM
mine was 1 fouled plug. to check, let the engine Idle and pull off each boot by itsel one at a time. If it misses more put it back but if you pull 1 out and it sounds the same its that plug.
Old Aug 4, 2007 | 01:06 PM
poorkid's Avatar
I tracked the problem to a fuel issue with carb #1 the pilot jet was plugged and I also eliminated the pairvalve and tubing.
Old Aug 16, 2007 | 07:25 PM
poorkid's Avatar
FYI the pair valve and tubing is requiredon the F3without it, itwill run like junk and won't hold a steady cruise above 40 mph
badtyler90
Sep 10, 2013 01:26 PM
Jopel
Jun 28, 2011 10:14 PM
metal cbr 600 f4
Jul 1, 2009 02:52 AM
sandslinger
Oct 30, 2008 01:43 PM
DKAP_600
Aug 30, 2007 10:45 PM
