CBR f3 engine problems
I can't find the cause of a miss at low rpm cruising and 1/4 to 1/2 throttle openings. The miss leaves under full throttle. Any suggestions? All the CV boots are good. I put new plugs in.I installed a Factory Pro jet kit and nothing made a difference. I have a Uni foam filter and aftermarket can.
RE: CBR f3 engine problems
It wouldn't be the main because the problem goes awaywhen I give it full throttle. Needle changes didn't make a difference. Are there any valves or senloids on the f3 that may affect the jetting? Also what are all the hoses by the air box goingbehind the carbs into some sort of valves?
