Carb sync w/ Hindle exhaust
Hey guys. Another quick question about my f3:
Bought it with a Hindle exhaust, and upon inspection of the carbs, we found stock jets and the adjustment screws misaligned.
1. Can I access these screws without taking out the air box to sync?
2. Is there anything online that someone has seen with setups for syncing with aftermarket exhausts?
Cheers.
Cheers.
Hey there.
1. If you are using the OEM air box, nope.
2. The process of syncing the carbs on a bike with an aftermarket exhaust isn't any different than with everything stock.
I think what you may be asking about jetting and your fuel to air ratio. That will be different than stock more than likely. Each brand of exhaust has a different affect on your f/a mixture. Hopefully somebody who has that brand of pipes can chime in. If not, it's a "try a little bit of this, try and little bit of that" type of thing.
