carb spray cleaner
Old Aug 6, 2010 | 03:13 PM
garythegrass's Avatar
Post carb spray cleaner
as anyone ever tryed honders spray carburretor cleaner if so what were the results replys gratefull thankyou
Old Aug 6, 2010 | 03:24 PM
dcaldwell's Avatar
i dont know about that kind, but i know myself, and plent of others on here, will definitely suggest seafoam.. about $9 a can at autozone or advanced auto
Old Aug 6, 2010 | 05:26 PM
Willkster's Avatar
Just a quick question about seafoam. What does it exactly do? Will it make the difference from not having to clean your carbs? Does it help unclog a jet? I am just curious of the wonders it has done for you guys. Thanks.
Old Aug 6, 2010 | 08:07 PM
jizzy's Avatar
i think seafoam worked way too well on my carbs that it probably dislodged some gunk and clogged up my jets (just a guess).. bike wouldnt go higher than 3k rpm.. and now it was only running on 2 cylinders.. took her to the shop and have my fingers crossed
Old Aug 8, 2010 | 11:35 AM
dcaldwell's Avatar
i have noticed mine runs a lot smoother at low speeds..no more sputtering...
Old Aug 9, 2010 | 04:36 AM
Willkster's Avatar
So you can only use this stuff if your bike is running? Just making sure. It helps if your bike is running kinda rough?
Old Aug 9, 2010 | 08:05 AM
dcaldwell's Avatar
i'm not sure as to how others use it, but ill dump some in my gas tank and and when it runs through the fuel system it will help remove some of the gunk that may be stuck in the carbs. i dont think it would be as effective as tearing your carbs apart and cleaning them, but this is a much easier way, just pour and ride.
its only $9 a can at autozone or advanced auto, so i figure its worth a shot. might take a few doses before you notice some results. it comes in a 16 oz bottle and i think the ratio is 1 oz/gal.
read this from their product website..
http://www.seafoamsales.com/motor-treatment.html
Old Aug 9, 2010 | 11:49 PM
Willkster's Avatar
Yo thanks a lot man. Ill try it out and see. Yea you never know. I wish i felt more comfortable taking the carbs off and just cleaning the crap out of them. But ill try this and hopefully it will work really well. Thanks again man.
mk929
Aug 15, 2008 01:55 PM
voodoochyl
Nov 10, 2007 11:59 AM
ptowntsi
Jun 7, 2007 09:54 AM
Cellesaurus5
May 8, 2007 01:00 AM
sirlimpzalot
Sep 5, 2006 02:13 AM
