Carb O-Ring Sizes?
Old Dec 26, 2013 | 04:22 PM
FOGeologist's Avatar
Senior Member and ROTM March 2014
Default Carb O-Ring Sizes?
I think I want to replace the o-rings in the T-fittings between carbs - like the coolant, the air vent tubes, and the fuel tubes.
I have measured 4 different sizes: The carb coolant barbs use 1.5 mm (cross-section) x 5 mm (inside diameter), the fuel Ts (gray Ts) use 1.5 mm x 8 mm o-rings, the air vents (the brown Ts) use 2 mm x 8 mm o-rings, and the single black air vent T uses two 1.1 x 15 mm o-rings. I took all measurements from the actual o-rings as they came off my carbs using a micrometer.
I am buying nitrile Buna rubber, which is good for automotive fuels and coolant applications, durometer 70 o-rings. Honda of NA wants something like $40 or $50 for a few o-rings. I am buying all of these for under $8 from a manufacturer online.
Please tell me that the sizing that Honda uses isn't peculiar in some weird way that I haven't spotted!
Mr Bentwrench
Dec 16, 2022 09:42 AM
3mbc
Aug 5, 2017 04:42 PM
txsmainevent
Jun 20, 2011 03:11 PM
ajreyno1994
May 11, 2011 05:26 PM
benvaldi88
Feb 16, 2007 08:28 PM
