Can't keep my "new to me" F3 running
Over the weekend I bought a 96 F3. It wasn't running when I bought it, and the guy that sold it to me said the carbs needed cleaned. When I got the bike home, I took the tank off and sprayed carb cleaner on the carbs and down the fuel line and got it to start a few times, but I can't keep it running. The longest I have had her running is about 15-20secs. After, I reconnected the fuel line to the petcock, thinking I would try with gas...Nothing. I then started thinking, maybe the petcock or the filter in the tank is clogged. So I took the tank back off and connected a tube to the petcock valve and ran it into a gas can, opened it in the down position like the manual says and Nothing. Shouldn't gas leak out if it is open?
Pull the petcock out and make sure the filter in it isn't blocked.
Cheers, SB
If the petcock has two lines to it, the larger one will be the fuel line and the other (smaller) a vacuum line that is connected to the inlet of the carbies. If it is that, it needs the carbies providing a vacuum to pull the diaphragm open in the petcock to allow the fuel to flow.
Cheers, SB
Cheers, SB
Also anywhere to find a pic or diagram to see where it connects to the carbs?
SB, my savior Thank You So Much!
I'm a huge noob when it comes to bikes, but without a doubt I am definitely in the right place here for help! I sprayed some more carb cleaner into the carbs, connected the fuel line and the vacuum line to the carbs (thanks to SB) and BAM...my f3 not only starts, but stays running! I also went to my local honda dealership and purchased a service manual, $35 but I have a feeling it's going to be priceless in my efforts to learn my bike inside and out!
Air + gas + fire = happy
Make sure all is balanced.
To me it seemed like the the black was not very wet, but it was slightly wet. So it seems that for dry black it was just lead fouled...BUT, for wet black my problem becomes oil fouled which is worn rings and pistons. I'm hoping that it isn't the latter, as that is a pretty decent sized job, from what I read. But, I replaced all 4 spark plugs with NGK Iridium IX CR9EHIX-9 plugs and she fired up instantly upon hitting the start button
Guys I am a review editor on a major PC hardware review site and we have a huge forum following with about at least 7K online at all times. Over there, I am the guy who helps out all the noobs...But, here my role is completely reversed, and I am a huge NOOB lol! When I get into something, I don't quit until I know all the ins and outs, and I can already tell after less than a week that my new motorcycle obsession will be completely dependent on the invaluable help I am getting here! It's different for me having the shoe on the other foot, but I really appreciate all the help I have gotten so far
i would still do a proper carb cleaning..where as spraying cleaner through the intake area really isnt doing much..
you need to pull the carbs off and actually clean the fuel side.
that entails pulling the float bowls, pulling the jets, and cleaning all of that out. the slow jets are normally the culrprit when it comes to fouled jets.the hole is very very small. i had to use a .009 guitar string to clear mine out!
KenG
CBR1000F For Sale / Found
08-09-2009 05:20 AM
Cerberus XJR
02-13-2009 03:22 PM
