Can someone please confirm this? so confused...
Old 04-07-2009, 12:35 PM
mr93t's Avatar
Default Can someone please confirm this? so confused...
I have a '96 F3.
When I removed the tank, in the "off" position, I had a tad bit of fuel dripping out.
when in the "ON" or "Reserve" position, Fuel will flow out like a water tap.
Is this correct? is it only on F2's which is should NOT have any gas come out on ANY position?
Old 04-07-2009, 12:42 PM
Gunnar's Avatar
My -97 does that as well, albeit it does not leak if it's exactly in "off".
A micrometer off the "off", and it drips.
Old 04-07-2009, 01:10 PM
mr93t's Avatar
Yes...same with mine. A micrometer off, and it will drip.
Ok.. thanks for confirming. I was getting so confused with all the info from the search results.
I guess this is because we have a fuel pump? where the F2 does not havea fuel pump?
Old 04-07-2009, 01:36 PM
MrBomb's Avatar
i may be incorrect but i thought it was supposed to be a vacuum system, so there shouldn't be any fuel coming out without the pump running, again i may just be talking out my a$$ but i thought that is what i read on here not to long ago
Old 04-07-2009, 11:24 PM
The F2's used a vacuum to operate the opening of the petcock. On the F3, they switched to a manual one. If you open it and there is fuel in the tank, it flows like a garden hose.
Old 04-07-2009, 11:55 PM
f3BikeR's Avatar
My '95 doesn't drip at all at "off" but my buddy's '98 SJ sure does, unless you're EXACTLY at off, and even then it drips..
Old 04-08-2009, 08:46 PM
mr93t's Avatar
Thanks guy...
I'm going to assume my '96 is OK.
When bang on "off" it hardly (if at all) drips. Any other setting and .. yes.. pours like a garden hose.
Many thanks!
steve.zodiac
05-29-2012 12:44 PM
slamd_f2
08-07-2009 11:50 AM
Speedin4Fun
05-14-2009 09:55 AM
tribb333
02-18-2008 01:52 PM
MikeInCtown
08-14-2007 06:17 PM
Quick Reply: Can someone please confirm this? so confused...
