Can I go to a track without fuel pump on CBR F3.
Hello there,
I am having issues with my CBR F3's fuel system. Last week bike stopped on highway due to fuel pump failure. I got a new pump but the problem remained. Seems like the pump stops pumping gas and the bike just rans out of fuel. Checked relay, pump, some circuits and other stuff. Dont know for sure what is wrong. I dont have much time. My track days is due next Monday.
So, my question is. Can I do my track day without the pump on my bike? I plan on just buying a fuel hose line and put it directly between gas tank and carbs. I know I ll have issues on higher speeds. But still its better to run slower than just loose my track day. I won't be able to get new relay (if it is relay that causes the problem) so soon.
If you have any other thoughts of what else I could test I would appreciate it. Also If you happen to have cut off fuell relay I ll be glad to buy it.
Thanks.
Thanks.
Its not an easy fix. And I dont think its a dumb question at all. If you dont know the subject please do not say that. Yes, I checked a lot of stuff. And right now I am planning on changing relay. I cant get one so soon. So my only option not to loos my track day is bypass the pump. Or may be you have a spare relay???
All too often, you see very intelligent, experienced people who jump right to 2nd-tier troubleshooting steps, because they're so used to managing more difficult issues, only to find that it was some basic scenario (such as a blown fuse) that simply slipped their minds while contemplating the depth of the problem.
If you think your relay is the problem, why are you talking about bypassing the entire pump subsystem? You could run a wire from the power source straight to the pump, thus bypassing only the relay. If the pump then works, you know its your relay. If not, you know its the pump, and you saved the ~$80 for a part you don't need. If the pump does work after bypassing the relay, head to Radio Shack and get yourself a toggle switch, and wire it all up to make your own "manual" relay. You'll have to flip it on your own, but at least you'll get pump functionality, and get more out of your day at the track then having to just deal with low speeds on a "gravity" feed.
As proof of concept, here's a thread with someone who did exactly what I reccomended, and claimed everything works fine like that:
https://cbrforum.com/forum/900-modifications-44/need-tech-nerd-experienced-mechanic-please-94906/
https://cbrforum.com/forum/showthread.php?t=94906
Kopi Ko
10-01-2019 08:29 AM
Red97tib
CBR1000F For Sale / Found
09-03-2013 10:06 PM
