Broken Plug!
Old Aug 22, 2013 | 06:17 PM
Ricecooker's Avatar
Default Broken Plug!
First off to start, my name is kevin and im a GM technician. couple days ago i picked up a 96 600f3. quit smoking, broke up with the girl, felt like a deserved something fun. use to ride a few years ago i figured id get back into the game. so i bought it, did a carb job yesterday but it was blowing out cylinder 1 coil. i figured it was just not grabbing the top of the plug. so today before riding it home, id just double check make sure the plug is tight and get it to sit right on the plug. sooooooo turns out the plug broke in the head and the non broken part is hanging in the head.
i was wondering if this happened to anyone. for me, its down to pulling the head and extracting this SOB, or try to fit an easy-out down the cylinder.
is it possible to access the bottom of the cylinder via carb removal.
just looking for some input.
Kevin
862-268-0520
Old Aug 23, 2013 | 03:46 AM
jackojeff's Avatar
Kevin
862-268-0520
wouldn't even bother with an easy out i would just pull the head off and get it out that way and while the head is off re-tap the threads just to be on the safe side
what do you mean 'did a carb job'?
you can also do your valve clearances and put a new camchain on there whilst your at it. how many miles does it have on?
Old Aug 23, 2013 | 06:13 AM
74demon's Avatar
How much of the plug is still in there? Is the metal part with the nut intact, or is that broken off?
As a GM tech, you should be able to extract it with no problems.
Old Aug 23, 2013 | 10:09 PM
Ricecooker's Avatar
was about 3/8 in the cylinder. i got it out. hammered an easy out down there, spun it and it came out. took awhile to find the right size but worked like a charm. stuck a magenet down and got anything on top of the piston then turned over the engine a few times to blow out the rest. put in new plugs and good to go.
ill post pictures when it comes threw my email
Kevin
Old Aug 25, 2013 | 08:34 PM
Congratulations on two fronts. For choosing an excellent bike and for quiting smoking. Both are excellent choices. Good job on getting the plug out. Changing plugs on these bikes is similar to changing plugs on a 70's era big block chevy with AC. Not a whole lot of room to work with.
Anyway, welcome to the forum as well.
Old Aug 25, 2013 | 08:55 PM
Sebastionbear1's Avatar
Kevin
862-268-0520
More than enough reason!
Welcome to the CBR Forum Kevin. And good job with the repair.
Cheers, SB
Old Sep 9, 2013 | 07:15 PM
Ricecooker's Avatar
thank you and i must say this bike runs amazingly now that were firing on all 4 cylinders hahaha
pipedcbr
Dec 29, 2010 12:25 PM
Vince492
Jan 28, 2010 09:34 PM
allnath3
Nov 5, 2006 12:31 PM
grass
Jun 16, 2005 04:03 AM
