bought another CBR this one non running anyone want to help?
Old Sep 19, 2014 | 11:45 PM
  #31
gamekiller7's Avatar
Well good news is she runs!
Bad news is my throttle only has like a 1/4in play so I'm guessing I need to go down and adjust the nuts on the ends of the cables?
Hopein I only have to take the intake off to get to that.
Old Sep 20, 2014 | 07:46 AM
  #32
A quarter inch play or rotation ? I'm thinking you're talking about only that much rotation. Did you check the ability of the butterfly/throttle to rotate fully before putting them on the bike ?
Old Sep 20, 2014 | 09:38 AM
  #33
Yes rotation and before carbs were off it was a normal throttle.
Old Sep 20, 2014 | 10:20 AM
  #34
I realize that this may seem like a stupid question, but there isn't any possibility that you attached the cables backwards is there ? The adjuster nuts on the cables would adjust the amount of slack in the cable, but I can't imagine being able to adjust it in such a way that the throttle only moves 1/4".
Old Sep 20, 2014 | 11:34 AM
  #35
No I'm almost certain I put them on right I made one cable hang high in the air and the other lay far down so when I went back I knew top and bottom.
Old Sep 20, 2014 | 11:38 AM
  #36
A good safety tip is to mark them with a sharpie before you start. It has kept me straight a couple of times.
Old Sep 20, 2014 | 11:57 AM
  #37
Conrice's Avatar
Hold both cables in you hand and watch what they do when you twist the throttle. The spin the cam on the carbs assembly. It should be pretty obvious which way the have to go on. This MUST be something you did when you hooked the cables up IF the cam spun the carb butterflies open before you put the carbs back on the bike.
I have to be honest though, 1/4 in play in throttle shouts out to me that the cables are reversed unless the bike revs freely. 1/4 in rotation when there is no load on the engine (when it's in neutral) should make the bike rev really high, so if the engine doesn't really respond to the twist, the cables are reversed.
Old Sep 20, 2014 | 01:45 PM
  #38
I can rev it freely. I don't think the cables were put on wrong. Just road it as is and wouldn't go over" 90" didn't feel like 90. Maybe I just need to adjust the nuts on the throttle cables at the carbs?
Old Sep 20, 2014 | 09:37 PM
  #39
Well after it flooding out on me on the road and being stuck for a bit. Found out all it was, was that I had a hose under when it should have been over and it was catching the throttle return. Gunna test ride her tomorrow wet roads here right now.
Old Sep 20, 2014 | 11:28 PM
  #40
Well, clearly I didn't understand what the issue was that you were describing. I"m glad it's sorted out though.
