bike boggs between 0-5000 rpm...
if you pull the choke lever on a little does the running problem go away or get worse...? If it gets better the carbs are dirty.
Fuel from the carbs is delivered by 1 of three "circuits" or paths. idle and just off idle is handle by the "idle" circuit.Then light throttle is the "pilot" circuit...mediumto full throttledelivers fuel through the "main jet/needle" circuit.. The passageways in the first two of theseare pretty small, and can plug up.
There are various topics in here on cleaning carbs yourself...good luck
