Battery acting up
Old Nov 18, 2010 | 09:26 AM
Tremar's Avatar
Default Battery acting up
To start I have a 96 f3, and an 8000K HID (unsure if this will be relevant)
My battery died a few times this year, leaving me stranded on multiple occasions. So I replaced it.. all seemed well, however twice now. I will ride for like 30 minutes or so, then stop and when i go to start my bike, it is as if my battery is dead. Luckily I have been with a riding buddy both time, so he push started me.
When I returned or got where I was going (another 30 minutes or more), and shut my bike off. Then hit the start button and it fired right up no problem. Leave it sit for a while, starts right up.
It is extremely strange as this only happens once in a while and not everytime.
Any thoughts?
Old Nov 18, 2010 | 10:59 AM
cgmiller83's Avatar
Check your rectifier and stator. The rectifiers on F3 are a weak point. On my blackbird the stator was acting up. It has 3 phases and 1 was working off and on. Changed it out, no problems now. It also has a HID kit installed.
Old Nov 18, 2010 | 11:06 AM
Tremar's Avatar
Thanks for the quick response. How exactly would I ensure that is what needs to be replaced before actually replacing it?
Old Nov 18, 2010 | 07:33 PM
When you describe that it acts like it's dead, do you mean it will turn over very slowly like a weak battery ? Or you hit the starter button, and your headlight turns off, but the bike doesn't even try, like totally dead ?
Old Nov 18, 2010 | 07:42 PM
Tremar's Avatar
Turns over very very slowly
Old Nov 18, 2010 | 07:50 PM
2 things I'd check.
  1. Have the battery load checked at an auto parts store to make sure it doesn't have a bad cell or something similar.
  2. Put a meter on the battery while it's running. You should get 13v to 15.5v @ 5,000 rpm.
  3. Clean the battery terminals with a wire brush.
(ok 3 things)
Old Nov 19, 2010 | 01:18 AM
Tremar's Avatar
Originally Posted by IDoDirt
2 things I'd check.
(ok 3 things)
The battery is only a few months old, but I have put it on a meter and the last time I checked it was fine. Me and my bike are 100 miles apart as I am at school.. But when I am home over break I will check it again
Roman30
Apr 25, 2012 02:49 PM
mbison83
Jan 12, 2011 12:16 PM
cbrf4bp
Mar 17, 2009 02:11 AM
fireblade929
Oct 14, 2007 05:09 AM
Mstngdrew232
Mar 13, 2007 01:42 AM
