Back Suspension
Old Jul 27, 2007 | 11:13 AM
SLY_Z_28's Avatar
Default Back Suspension
What setting (1-10) do you set the back shock. Its a little stiff for me and i weigh 135. Is up the # softer, or down the number? thanks
Old Jul 27, 2007 | 01:37 PM
gixxereater's Avatar
Default RE: Back Suspension
Compression damping is lower numbers equal softer.......try turning down the pre load (the adjuster right above the spring) and maybe reducing rebound (if it's adjustable for that). You might also be feeling a "harsh" ride from the front too. If it's too stiff it may FEEL like the rear so soften that up a touch too.
Old Jul 27, 2007 | 02:29 PM
Darkside19's Avatar
Is there a way to raise the overall ride height of the rear end?
Old Jul 27, 2007 | 02:38 PM
Either increase the pre load (although that is not the right way to do it) OR shim it with washers between the shock body and the subframe.(where they attach at the top) OR you could drop the forks a little in the triples, but be careful to watch for clearance with the front tire and the radiator. 5-6 mm is about all I would go in the front to begin with. You might be able to get away with 10mm, but again......it depends on clearance.
Old Jul 27, 2007 | 03:31 PM
madmike01uk's Avatar
Mine has been set on 2 which is the factory standard setting which was a bit soft for me (I weigh about 185lbs) So I have stiffened mine up to 4 which gives me more confidence in the bends.
mark1200
Track Techniques
Mar 1, 2011 07:42 PM
domon
Oct 3, 2007 10:42 AM
exup547
Sep 14, 2006 08:10 PM
exup547
Sep 14, 2006 04:40 PM
06CBRF4i
Jul 22, 2006 02:12 PM
