adjusting the handlebars?
Old May 14, 2008 | 08:51 PM
bluestanger66's Avatar
Default adjusting the handlebars?
i was just wondering if there was a way to adjust the angle of the handlebars. i can move them a little bit when i loosen the bolt, but i was wonderin if there might be a way to make more of an adjustment. it seems like they are angled in way too far!! thanks for the advise as always
Tyler
Old May 14, 2008 | 08:57 PM
kwong2001's Avatar
Default RE: adjusting the handlebars?
You'd have to cut off the big tab thing to make them angle adjustable.
Old May 14, 2008 | 08:59 PM
but that wouldnt mess anything up if i did that? thanks for the quick response
Old May 14, 2008 | 09:50 PM
kwong2001's Avatar
No, but they're more for safety just incase you didn't tighten the bolts holding them on. Same with the little rings on top of the forks.
Old May 14, 2008 | 10:25 PM
pacemaker's Avatar
See if you can get hold of an Italian bike for a few hours, once you get back on the CBR you'll think your riding a cruiser. I've seen adapters (risers) for different bikes, so do a bit of research.
Old May 14, 2008 | 10:33 PM
redzintimidator's Avatar
just cut the tab off...but youd better make dam sure they are tight and will stay tight. you go to turn n your handlebars come off....
not good
badbilly70
Aug 1, 2012 09:38 PM
MDiMatteo56
Feb 25, 2007 10:12 PM
adam833
Jan 19, 2007 11:09 PM
diechrome
Sep 1, 2006 09:52 PM
lumberman
Aug 12, 2005 12:42 AM
