98 f3 chain and sprocket ?
Old Apr 5, 2010 | 02:23 PM
asides's Avatar
Default 98 f3 chain and sprocket ?
ok i have the 98 which uses the 525 chain. but i found a good deal on the 520 chain with afam sprockets but its 520. so my ? is it says 91-96 are the sprockets the same or diff thanks
Old Apr 5, 2010 | 02:40 PM
adrianinflorida's Avatar
the '91-'96 uses a 530 chain, therefore it would be a different pitch than the 97-98, which uses a 525 chain. Not sure about mixing and matching sprockets and chains of different pitches (520, 525, 530)
Otherwise, they are the same sprockets (bolt spacing and diameter) on all of the F3's.
Old Apr 5, 2010 | 03:45 PM
asides's Avatar
the kit comes with the sprockets i was wondering if thet were the same all years. so since it comes with everything it should be good then
Old Apr 5, 2010 | 03:57 PM
From what I can tell, yep, except for the pitch, the sprockets are the same for all F3s
Old Apr 5, 2010 | 04:21 PM
asides's Avatar
people run the 520 conv its cheaper and saves weight also but may not last as long
Old Apr 5, 2010 | 04:23 PM
broadie's Avatar
5 is the pitch the 20 or 25 is the width.
The kit will fit fine but it's more for racing.
Old Apr 5, 2010 | 05:38 PM
Just trying to add a little clarification here on chains. As broadie says, pitch is the spacing between the rollers and the 5 refers to that. So 530, 525, and 520 have the same Pitch. The roller width, or distance from one side plate to another is different, the smaller the last two numbers, the narrower the chain. 520 sets generally have sprockets made of an aluminum alloy, which is softer and lighter. Yes there is less mass to move, but it's not going to last as long. There is not much of a gain by going from a 525 with steel sprockets to a 520 with aluminum sprockets (at least not as much as you would if you were going from a 530 with steel sprockets to a 520 setup.
Here's a nice explanation of chain basics I came across.
Chain and Spockets
Old Apr 5, 2010 | 05:42 PM
Thanks for clarifying that. I was mixing pitch and width in my posts.
Old Apr 6, 2010 | 05:16 PM
Speedemon636's Avatar
Pretty good price here.. It's OEM mind ya.. Can't go wrong. From what I can tell it's the engine sprocket, rear sprocket, and complete chain for about $130.. #27 on list http://www.cyclepartswarehouse.com/f...1998&fveh=3047
Old Apr 24, 2014 | 02:42 AM
townsend3111's Avatar
Default Sorry to jump on !
Sorry to jump on the end of the thread! But I'm a bit confused about my chain and sprocket..
Originally I had a 14 toothed sprocket at the front and a 43 at the rear.
Ordered a new set ( asked the assistant if it was the correct one on which he said yes to ) however, now I have them, the front is 16 toothed - doesn't fit to the transmission though and the rear is 44.
Would the performance of the bike be affected if I run a 14 on the front at 44 on the rear?
Thanks in advance!
