98 f3 chain and sprocket ?
ok i have the 98 which uses the 525 chain. but i found a good deal on the 520 chain with afam sprockets but its 520. so my ? is it says 91-96 are the sprockets the same or diff thanks
the '91-'96 uses a 530 chain, therefore it would be a different pitch than the 97-98, which uses a 525 chain. Not sure about mixing and matching sprockets and chains of different pitches (520, 525, 530)
Otherwise, they are the same sprockets (bolt spacing and diameter) on all of the F3's.
Here's a nice explanation of chain basics I came across.
Chain and Spockets
Pretty good price here.. It's OEM mind ya.. Can't go wrong. From what I can tell it's the engine sprocket, rear sprocket, and complete chain for about $130.. #27 on list http://www.cyclepartswarehouse.com/f...1998&fveh=3047
Sorry to jump on the end of the thread! But I'm a bit confused about my chain and sprocket..
Originally I had a 14 toothed sprocket at the front and a 43 at the rear.
Ordered a new set ( asked the assistant if it was the correct one on which he said yes to ) however, now I have them, the front is 16 toothed - doesn't fit to the transmission though and the rear is 44.
Would the performance of the bike be affected if I run a 14 on the front at 44 on the rear?
Thanks in advance!
Thanks in advance!
