'97-'98 Clear Alt. Intregrated Tail - HELP!!
Old Jan 24, 2010 | 12:14 PM
Speedemon636's Avatar
Question '97-'98 Clear Alt. Intregrated Tail - HELP!!
I know this has been talked over many times, but I couldn't seem to find the answer to my problem.. I bought this light off of ebay and the connectors from the light to the harness are different. Are the brake light connectors supposed to go to the resistor and then the harness because I've seen some that have the normal bulb end that plus straight into the stock bulb socket??
Old Jan 24, 2010 | 05:32 PM
intiractive's Avatar
i know nothing about this, but will try and attempt to offer some help. i see the green connector with 4 pins. im guessing the pinout (in no particular order) is left turn signal, right turn signal, brake, and running lights. looks like the 2 brass or copper pins for the mounts are the negative.
if ALL else fails, put ground (im assuming its ground for the mounting pins) on it, and touch each pin on the connector with a 12v battery with a wire connected to simulate each function you want. that way you can figure out the pin out. use the volt meter on your wiring harness to figure out its pin out... and solder.
sorry to provide any bad info about this, this is jsut a worse case scenario!
Old Jan 24, 2010 | 05:57 PM
willduce's Avatar
The resistirs get wired between the turn signal wires. The yellow hooks up to the colored wire side of the resistior. So the resistor get hooked up to blue wire and yellow on one side and green on the other side od resistorm same thing on other side but I think it was orange wire not blue. For the regular hook up I think that brown goes to red I can't remeber how the others went off the tope of my head.
Old Jan 24, 2010 | 07:13 PM
Thanks for the info! So willduce, you're saying I need to just buy the resistor and all will work out fine?
Old Jan 24, 2010 | 07:49 PM
willduce's Avatar
Yeah resistors will keep the blinking rate normal speed. U can get them From clear alternatives for 5 bucks. Ill get u the rest of the wiring color codes tomorow. Sorry for bad grammer in typing on my phone
Old Jan 24, 2010 | 07:53 PM
willduce's Avatar
Pm me your phone #. Ill take a pic of the wiring harness so u can see how the resistors go. Ill send u a pic tommorow
96CBRJimmy
May 27, 2011 07:46 AM
marky82
Sep 9, 2009 03:34 PM
kdog
Jun 26, 2007 01:12 PM
