96 to97 tail?
Old Jan 7, 2012 | 02:27 AM
daddywilson's Avatar
Default 96 to97 tail?
What all is needed to swap the tail of a 96 to a 97? I know u need the 3 tail plastics the tail light and the seat do u need anything else to mount the tail light or anything else?
Old Jan 7, 2012 | 02:34 AM
pommie's Avatar
Not having an F3 as yet, so dont rely on this.
I contacted a fairing supplier in Aus yesterday and that was there advice... plastics and light, and seat.
Old Jan 7, 2012 | 03:06 AM
pommie's Avatar
Sorry just realised that my reply doesnt help at all.
I think you're right in your thinking.....I dont think the subframe differs much.
Old Jan 7, 2012 | 04:01 AM
ianp5uk's Avatar
I "think" it does differ although maybe not much. I bought a mudguard/number plate holder from a 96 and it didn't quite fit my 97. Some fittings didn't seem to line up. But ........ my bike has been messed around quite a bit so maybe on stock bikes it would fit.
Old Jan 7, 2012 | 02:16 PM
orangef3's Avatar
In order to go from 96-97 you are going to need the above mentioned parts as well as the tail light bracket for the 97 in order for things to go together correctly
Old Feb 17, 2012 | 08:57 AM
do u have to have the taillight bracket or can the one there work?
Old Feb 17, 2012 | 03:42 PM
SpongeRR's Avatar
No, the 97 tail light wont fit the 96 bracket, found this out myself when i fitted a complete 97 fairing to my old steelie.
As has been said you will need the tail light, bracket, rear side and centre tail fairing, the grab handle if you are intending on fitting one and the seat.
Old Feb 17, 2012 | 08:08 PM
Cr250r67's Avatar
OrangeF3s right you will need the bracket. It relocates the tail light to sit higher in the new tail and relocates two of the rubber grommets that the plastic pins in the tail snap into. You can however use the 96 seat with the new tail it just does not cover two small spots and fits tight.
Old Feb 17, 2012 | 09:26 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
see my seat conversion in my sig
Old Feb 18, 2012 | 03:37 PM
SpongeRR's Avatar
You can but it looks horrendous, i found all that out when i bought 97/98 fairings for my 95/96 bike.
You should be able to pick up a cheap secondhand seat on ebay, they usually come up quite a bit.
cds83
Jul 3, 2013 12:05 AM
Hootie233
Aug 25, 2010 03:08 PM
