96 to97 tail?
What all is needed to swap the tail of a 96 to a 97? I know u need the 3 tail plastics the tail light and the seat do u need anything else to mount the tail light or anything else?
I "think" it does differ although maybe not much. I bought a mudguard/number plate holder from a 96 and it didn't quite fit my 97. Some fittings didn't seem to line up. But ........ my bike has been messed around quite a bit so maybe on stock bikes it would fit.
No, the 97 tail light wont fit the 96 bracket, found this out myself when i fitted a complete 97 fairing to my old steelie.
As has been said you will need the tail light, bracket, rear side and centre tail fairing, the grab handle if you are intending on fitting one and the seat.
OrangeF3s right you will need the bracket. It relocates the tail light to sit higher in the new tail and relocates two of the rubber grommets that the plastic pins in the tail snap into. You can however use the 96 seat with the new tail it just does not cover two small spots and fits tight.
You should be able to pick up a cheap secondhand seat on ebay, they usually come up quite a bit.
cds83
Jul 3, 2013 12:05 AM
Hootie233
Aug 25, 2010 03:08 PM
some parts for sale.. tail cowl, tail light w/ mounting bracket, gauges, red frame sliders must sell
cannon
Aug 11, 2007 07:58 AM
