900rr swap into f3
Old Jun 23, 2010 | 10:28 AM
grizzly's Avatar
Originally Posted by Project96
Better yet get you some 900 sleaves & put them into your upper F3 cases with 900 pistons. There will definately be some machining work but has been done. With the difference in stroke & the increased combustion chamber it comes out to a 698 I believe. Ive seen 2 in my 10yrs in the industry & they were screamers.
PM sent! does any one have more info on this? i have my own machine shop and i plan on doing this very swap.
Old Aug 12, 2013 | 10:00 PM
jneedee's Avatar
Registered Users
There are no "upper" cases on the F3. The crank and engine are one and the same. You have to split the cases. in half... That kind of a stroke up will kill the bottom end of the engine in no time. The 900cc engine swap makes more sense.
Old Sep 4, 2013 | 10:02 PM
Project96's Avatar
The crank & cases are most definitely NOT 1 in the same thing. There are 2 case halves, upper & lower. The crankshaft must turn inside the cases, so how can they be one in the same??
Old Sep 5, 2013 | 08:45 AM
jneedee's Avatar
Registered Users
So sorry. I left out A WORD and you decided to respond with many words in a confrontational manner.
Harrumph (clearing throat)...
There are no "upper" cases on the F3. The crank and engine CASES are one and the same. You have to split the cases. in half... That kind of a stroke up will kill the bottom end of the engine in no time. The 900cc engine swap makes more sense.
Is that better?
Old Sep 6, 2013 | 09:01 AM
Project96's Avatar
The words I chose to use doesn't matter...
The crankshaft & the engine cases are NOT one in the same. The crankshaft does go inside of the engine cases, as does a few other parts & pieces. There are 2 halves to the cases. Upper & lower case halves. They aren't even made of the same material & they should never come in contact with one another in a well running engine.
The 900 crankshaft will not even go into a set of 600 cases. The 900 sleaves can be installed into the UPPER case halves of a 600 with some machine work once the 600 sleaves have been removed.
Old Sep 7, 2013 | 06:15 AM
jneedee's Avatar
Registered Users
For Crying Out Loud! Learn to read! I said Crank AND Engine CASE! (As in Crank CASE AND Engine CASE) Yes they are exactly the same (in this situation), if you can comprehend the English language. As far as anything else you have to say it sounds like you're arguing with yourself. I'm done with this thread.
Old Sep 7, 2013 | 07:42 AM
74demon's Avatar
I'm done with this thread too.
Why reply to a 3 year old thread then turn it into an argument?
Closed.
mariof
F2 Tech
Apr 18, 2010 09:09 PM
jrode
Feb 8, 2010 01:55 PM
lonewolfcbr
Jul 28, 2008 12:44 PM
exz5string
May 27, 2008 10:23 AM
k_hausser
Sep 4, 2007 02:22 PM
