900rr swap into f3
Old Jan 20, 2010 | 11:48 AM
dsnow77846's Avatar
Default 900rr swap into f3
is it possible? my friends 900 has been put into retirement but the engine is okay is it possible to do a swap?
Old Jan 20, 2010 | 12:09 PM
chuckbear's Avatar
Anything is possible.
Are you asking if it's a straight bolt-up?
Don't count on it.
chuckbear's Avatar
Let me just come out and say "no".
Old Jan 20, 2010 | 12:57 PM
Project96's Avatar
The rear motor mounts will go in but the front will not mount. You will basically have a hanging motor.
Better yet get you some 900 sleaves & put them into your upper F3 cases with 900 pistons. There will definately be some machining work but has been done. With the difference in stroke & the increased combustion chamber it comes out to a 698 I believe. Ive seen 2 in my 10yrs in the industry & they were screamers.
Old Jan 20, 2010 | 01:32 PM
bubba_finch07's Avatar
custom motor mount... or custom motor? either way sounds fun
Old Jan 20, 2010 | 03:51 PM
intiractive's Avatar
how mechanically inclined are you? how dedicated are you? Im guessing you already have an F3. Is it worth the downtime of not riding the bike? Are you gonna get halfway through the project and lose interest and try to sell it for scrap? Not only think about the custom motor mounts, but will the chain line up right? will the rear suspension be ok? will the radiator be adequate for the bigger motor? fuel lines, vacuum lines, throttle + choke lines, exhaust, intake.... there is alot of stuff involved. Not to discourage you, i would love to see one built!
Old Jan 20, 2010 | 05:52 PM
dsnow77846's Avatar
well ive tested gasoline
Old Jan 21, 2010 | 10:02 AM
Amongip09's Avatar
Im newI have 323 f ba with z5 engine. I would like to swap enigine. I have B6T engine with all needed parts, tranyI dont know if this motor fix into my ba Can I Swap this motor wihtout serious troubles?
Old Jan 21, 2010 | 11:43 AM
95&97_cbr_f3's Avatar
I've actually seen a craigslist posting and the guy had a 900rr motor in a 95 f3. if i remember correctly the only mounts that had to be fabbed up were the mounts by the carbs. Also he had to notch a wee bit of the frame for the top of the motor. he also got a in tank fuel pump. maybe even used the f3 wire harness. i know the f3 spark box is an upgrade for the 900 motor. hope this helps.
Old Jan 21, 2010 | 10:07 PM
kjohnson's Avatar
It's the side rail motor mounts.Old school cheater trick.
