520 Conversion question
Old Jan 30, 2006 | 04:10 AM
jaboyak's Avatar
Default 520 Conversion question
How far off would the speedo be?
I searched and couldn't find anything...
Thanks guys.
Old Jan 30, 2006 | 04:39 AM
NINE2NINE's Avatar
Retired Mod
Default RE: 520 Conversion question
need more info. if you go with the same gearing as stock then your speedo would read the same as it does now. but change the gearing, who knows? what do you have now and what are you going to?
Old Jan 30, 2006 | 10:17 AM
Muz's Avatar
Muz
Yep, if you just do a 520 conversion and keep the same sized sprokets the speedo will read the same. If you get different sized sprokets (ie 15 teeth instead of 16) then the speedo will be out
Old Jan 30, 2006 | 07:37 PM
Mark52403's Avatar
I thought F3's had the speedo connected to the front wheel?
Old Jan 31, 2006 | 12:07 AM
transamlt1man's Avatar
Nope its not that old. lol The 520 will not change your speedo. Anyways don't worry about your speedo being off if u change your gear ratio because they are not right to begin with. At least mine is like 10mph off at 70 with the stock gearing.
nvanvlymen
Apr 26, 2011 02:28 PM
stretch_the_apex
Sep 3, 2010 10:53 PM
samill42
Mar 26, 2008 03:16 PM
birde
Oct 17, 2007 01:13 PM
f4123
Jun 7, 2006 01:52 PM
