2nd gear issues
Old Apr 2, 2012 | 01:47 PM
derekvercher's Avatar
cbr 600 f3 oil pan gasket | eBay
theres one for you. in the manual it says to use a gasket maker paste or what ever it is. you can get this aftermarket cheap.
Old Apr 9, 2012 | 08:29 AM
djkain's Avatar
brand new shift fork installed and engine back into the bike. engine mounted just need to install the new chain and lock the rear wheel and give it a test drive.
Old Apr 9, 2012 | 08:15 PM
Jeffrey's Avatar
When you had your bike apart, did you happen to notice what shape the shift drum cam is?
Did it have triangle house shaped peaks or rounded points?
Old Apr 10, 2012 | 06:13 PM
dyracuse's Avatar
97/98 does NOT use a gasket, just sealant, they changed that over as well as some other small changes.
Old Apr 10, 2012 | 06:16 PM
dyracuse's Avatar
also, I have heard it is possible to change just the shift forks with a simple pan drop in bike if you drain the bike and tip it over in the grass, however, you would have a hard time seeing the condition of the dogs I would think
Old Apr 10, 2012 | 07:14 PM
djkain's Avatar
The dogs were good it was just the clutch fork that was worn. Ok I got everything back but now when I put the bike in first gear and give it gas I get nothing. I thought something was funky when I had to make the clutch adjuster to the max. Any ideas?
Old Apr 10, 2012 | 07:42 PM
djkain's Avatar
I just jacked the bike up the bike goes into first gear with a kathunk the rear wheel spins a little but when i throttle up the tire dosen't spin any more. Need help
Old Apr 10, 2012 | 08:25 PM
Your gear shifter is upside down dude. The one your foot uses to change gears.
Old Apr 10, 2012 | 08:54 PM
djkain's Avatar
um nope I have it the right way see pic
Old Apr 10, 2012 | 08:55 PM
djkain's Avatar
Forgot to say that when the bike is in gear the tire will spin freely even when the bike is off.
