2 questions on the f4i gauge swap... please help quick im in middle of install
Old Jul 2, 2009 | 05:27 PM
jacked600's Avatar
Default 2 questions on the f4i gauge swap... please help quick im in middle of install
Hey all,
just installing the 2002 f4i gauges ($130cdn) on my 1998 cbr 600 f3
I have been reading about this speedo healer... or something... just wondering .. do we have speedo wires like the older bikes ? or does my 1998 already have the updated tone wheel style pick up so just installing the cluster and the 900rr switch would be all I need for the cluster to read speed, rpm and temperature ? no special tone wheel accessory or anything like that for the digital speedo to read?
thanks
-Lee
Old Jul 2, 2009 | 05:38 PM
cajunlowrida's Avatar
Ya, all you need is the 900rr temp switch. Everything else works fine. For speedo to be accurate you need a -1 front sprocket.
Old Jul 2, 2009 | 06:07 PM
daazndood's Avatar
hey.the vtr1000 has the same part # as the 900rr temp sensor would it work also?
Old Jul 2, 2009 | 10:56 PM
jacked600's Avatar
f4i swap was a complete and utter success, took in total including fairing removal and installation and mounting the tach around 2.5 hrs.... I found a single 16pin female and male harness, routed all the wires through it and have 1 single harness connector for the whole swap.
the only thing about the instructions I found that was confusing was the pink wire on the f3 to the green wire on the f3...... it said pink wire to f3 and green wire (other green wire) from f4i ... so I was confused so I pulled out the test light quick ...
everything is good ... going to do the temp sensor at work tomorrow, don't feel like getting the garage messy with coolant.
thanks again for everyones help ...
-Lee
Attached Thumbnails 2 questions on the f4i gauge swap... please help quick im in middle of install-img_0143.jpg
Old Jul 2, 2009 | 10:58 PM
jacked600's Avatar
what is the part number ? do you have it by chance ?
thanks
-Lee
Old Jul 3, 2009 | 05:10 PM
-Lee
Glad you got it together. Changing the sensor shouldnt allow any coolant to come out of your motor. That said, I hope you are aware the sensor is the one above the top waterneck on the right side of the motor, not on the radiator.
Old Jul 3, 2009 | 09:32 PM
jacked600's Avatar
is it called the thermo unit and is it located near the head on the right side of the motor ?
thanks
-Lee
Old Jul 5, 2009 | 10:22 AM
Yes thats it. Should be about $40-50 shipped.
Old Jul 5, 2009 | 12:06 PM
jacked600's Avatar
Thanks so much for all your help.... I am a tech at a honda car dealership... so Im hoping I can call a powerhouse and have them send it up to me dealer cost...
-Lee
Old Jul 6, 2009 | 08:54 PM
98nismo's Avatar
my thermo unit easily broke off just be careful. looks good btw
milianbenja088321
Feb 25, 2014 12:59 PM
hockeyryan
Jan 31, 2012 04:26 PM
intiractive
Sep 18, 2009 07:03 PM
Det99cbrf4
Jul 18, 2007 08:57 PM
Armstrong
Jun 8, 2006 08:31 PM
