Will a F4i or 600 or 900rr wheel fit on a f2 swing arm??
Old Aug 26, 2008 | 09:26 PM
n9ne_inches_later's Avatar
Default Will a F4i or 600 or 900rr wheel fit on a f2 swing arm??
Hey guys i was wondering i am trying to fit a little wider wheel on the back for the track so i can put a180-190 tire on the back is there any other rearwheels from any other honda's that will fit on a 92 f2?? (600rr 900rr etc.)Or is a possible to put a 180 on the f2 wheel? Thanks guys!
Old Aug 26, 2008 | 10:09 PM
lonewolfcbr's Avatar
Default RE: Will a F4i or 600 or 900rr wheel fit on a f2 swing arm??
f3 rim, half inch wider than ours, can help you get bigger tires, i think the biggest you can run on the f2 rim is a 170 without throwing off the geometry too bad
Old Aug 27, 2008 | 10:26 AM
oh ok great thanks for the info!! The reason i ask is because i have a F4 swingarm and rear wheel but i was just going to use the F4 wheel do you know if that will fit the F2 swing arm??
dodger79
Oct 21, 2012 02:08 PM
