why does my bike run like **** into the wind
RE: why does my bike run like **** into the wind
About Jetting...
With a K&N I would have assumed you were already at Stage I...if your carb is stock with a K&N surely you are getting too much air and running lean at high speeds/winds.
But...your shop is right...once you jet you will have to tinker all the time: hot, cold, wet, dry, high, low...
ORIGINAL: edwardtn
About Jetting...
About Jetting...
ORIGINAL: ChanCBR
It sounds like a air intake problem. Too much air coming in most likely. At least that is what is sounds like from the data u gave.
