vaccum issues?
Old 04-25-2009, 12:05 PM
camaropower's Avatar
Be careful on choosing an inline filter tho because if it is too long, it will cause your line to pinch, blocking fuel flow
Old 04-25-2009, 06:50 PM
Browntowns20s's Avatar
problem solvved my friends... after pouring over the technical drawings over and over again and piecing somethings together i found out what the problem was. the vaccum hose from the carbs was buried down below some other hoses and some things like that. so once i found it i hooked it all up and prayed for the best. well she fired up. so i got to take it for its maiden voyage last night. it was the first time i have ever ridden this bike. i bought it without ever riding or hearing it run, but after some new plugs, fresh gas and a little body work i finally got to ride it. so if it will ever stop raining i can enjoy my new investment
Old 04-26-2009, 08:47 PM
ok so now i rode it for a while, i shut it off and now it wont start. i had to drain the cylinders because it hydro locked with fuel. so now i am back at square one. it wont start this time and i am afraid we might have a coil issue. any ideas friends
Old 05-04-2009, 06:27 PM
iowan's Avatar
take the plug wires out one at a time and shove a screwdriver into it to were it touches the metal in the plug wire and then put rest of screwdriver 1/4in or closer to the frame of your bike without actually touching the fram... try and turn over.. if you see spark from the screwdriver to the frame then you have spark... if i were you i would look into getting your carbs cleaned... there is a great diy on this forum somewere for it
hbaum11
08-08-2013 07:07 AM
torence20
06-04-2013 10:52 PM
smokertoker
04-17-2009 03:57 AM
deek98
09-29-2006 07:36 PM
deek98
09-29-2006 07:18 AM
Quick Reply: vaccum issues?
