triple tree feels loose...
Are you sure it's the tree? Front bearings maybe? There are two 14mm bolts about 6-8" down from your guages on each side of the shocks...Tighten those...Also, 6mm allen bolts at the top too.
Good Luck!
RB
Good Luck!
RB
yeah i would say that your bearings are bad..if you get on the brakes hard can you feel it shift forward with like a thump sound? if so then its the bearings..
the big hex head between your bars in the center of the tree is for tightening it thought and replacing the bearings.
http://www.ronayers.com/fiche/200_02...mp;parent=5120
