Torque Specs
Old Feb 3, 2010 | 07:53 AM
flyboy1011's Avatar
Default Torque Specs
So I've been looking around for a while and still can't find what I'm looking for anywhere. All the manuals I find online are missing the first chapter which has what I need: torque specs. So if anyone has a manual or knows them off the top of their head I need the following:
-Rear Sprocket Bolts
-Front and Rear Axle Bolts
-Front Axle Pinch Bolts
-Front Sprocket Bolt(into the Drivetrain)
I think that's all. Thanks to anyone that can help me out.
Old Feb 4, 2010 | 10:48 AM
flyboy1011's Avatar
bump...where you at hersh?
Old Feb 5, 2010 | 03:57 AM
eweppley's Avatar
I'll try and remember to look in my manual when I get home from work today and post them up flyboy.
Old Feb 5, 2010 | 07:02 AM
Project96's Avatar
Rear Driven Sprocket Nut = 65 ft-lb
Rear Axle Nut = 69 ft-lb
Front Axle Pinch Bolt = 16 ft-lb
Front Drive Sprocket Bolt = 40 ft-lb
Hope this helps.
Old Feb 5, 2010 | 11:26 AM
flyboy1011's Avatar
Thanks man, I appreciate it...anyone got the front axle bolt? not the pinch bolts, but the one that actually goes into the axle
Old Feb 5, 2010 | 12:34 PM
eraser0's Avatar
43 flbs (60 Nm)
Old Feb 5, 2010 | 02:32 PM
flyboy1011's Avatar
eraser, you got the same numbers as project 96 for everything else? i wanna check and double check just to be extra sure.
Old Feb 5, 2010 | 04:31 PM
eraser0's Avatar
Correct, same as project 96.
Old Feb 5, 2010 | 04:42 PM
flyboy1011's Avatar
awesome...thanks all
97stang
Mar 21, 2009 10:10 AM
FosmoenAlex
Jun 11, 2008 07:25 PM
cain crx
Jul 13, 2007 03:51 AM
jmoney600RR
Apr 7, 2006 10:33 PM
NotSoMellowYellow
Mar 27, 2006 10:52 PM
