Vin Decoder
or
Login with Facebook
Too much oil
1991 - 1994 CBR 600F2
Too much oil
04-24-2011, 01:55 PM
Seadoomanls
Too much oil
What happens if you put 5 quarts in the motor?
Like
Seadoomanls
Send a private message to Seadoomanls
Find all posts by Seadoomanls
04-24-2011, 04:10 PM
buickid
Blow seals out and other unpleasentries.
Like
buickid
Send a private message to buickid
Find all posts by buickid
04-24-2011, 05:24 PM
adrenalnjunky
bottom of the crank is dipping into the oil and churning it into a froth. Also causing weird heat/cooling situation for the con-rod bearings.
If it is fresh oil - get a clean catch pan, drain it all out, then put the correct amount back in.
Like
adrenalnjunky
Send a private message to adrenalnjunky
Find all posts by adrenalnjunky
Tags
600
91
cbr
engine
f2
honda
oil
put
slightly
Back to Subforum
View Next Unread
bike dies after hard riding
11:40 PM
