Tap conversion
Old Jun 30, 2020 | 02:51 PM
Christo Christo's Avatar
Default Tap conversion
Is a 5/16” The same as M8-1.25 for a Tap to to tap the fuel bowl on carb of CBR600F2 94
Old Jun 30, 2020 | 03:02 PM
74demon's Avatar
No
Old Jun 30, 2020 | 03:16 PM
Default Conversion
Do know what tap I would need for for 5.16” by any chance
Old Jun 30, 2020 | 04:31 PM
74demon's Avatar
You need the tap for whatever size it is. It should be metric. Use the plug to size up the correct tap.
Old Jul 1, 2020 | 07:34 AM
Phil314's Avatar
The bolts for the float bowl should be 5x16 - that is 5mm diameter by 16mm long.
They are metric. 5mm bolts usually have a .8 pitch.
So the tap you need would be a 5mm x 0.8 tap.
However, carbs are cast from cheap pot metals. They are soft.
So my first choice would be to use a thread chaser to clean out the threads, instead of a tap and cutting new ones.
If that doesn't work, you can always try tapping later, but you might need to go up to a 6mm tap in that case.
Old Jul 1, 2020 | 09:10 AM
74demon's Avatar
Is that the size for the bolts that hold the bowl on or the drain bolt? I was under the impression he was sizing up the drain, if there even is one now that I think about it.
Old Jul 1, 2020 | 09:21 AM
The way I read it in another thread, it was the bowl bolts, not the bowl drain to which he was referring. I could be wrong in that though.
Old Jul 1, 2020 | 09:30 AM
Bowl needs taping soz for confusion just about to try chasing them first if that fails I will tap thanks for help
Old Jul 1, 2020 | 09:31 AM
To clarify, is it the fasters that secure the bowl to the carb body or is it the drain plug on the bowl?
Old Jul 1, 2020 | 09:41 AM
Carb body
