tachometer not working
Old Mar 2, 2008 | 06:38 PM
amipinoy's Avatar
Default tachometer not working
When I bought the bike the tachometer and speedomter didn't to work. I just found out today that the speedo cable is today. My friend and I figured out the culprit was either the drive or the speedometer itself. For the tachometer. We have no clue where to start. I own a 1993 CBR f2
Old Mar 2, 2008 | 08:21 PM
Sand.Man's Avatar
Default RE: tachometer not working
Fuse? Wiring?
Old Mar 3, 2008 | 01:30 PM
mobius9's Avatar
hey pinoy, the easiest way to check if it's the cable or the drive (for the speedo) is to take the cable off at the speedometer side, spin your front wheel, and see if it's still moving. In my case, it appears my problem lies in the mechanics of the gauge.
Old Mar 3, 2008 | 09:27 PM
amipinoy's Avatar
We did the speedo wire check and it didnt move. We suspect the drive because the wire itself moved when we manually rotated it from one end. As for the tach we got continuity, so anyone got a replacement tach?
Old Sep 10, 2020 | 08:46 AM
rob245360's Avatar
Thumbs up Tacho not working
I took my cluster off the bike my speedo and tacho were not working i found that moistue must have entered the electrics at the back of the guages I cleaned all the screws and washers at the back of the cluster that were coroded and they both now work my speedo is the sensor type and not the cable type. The tacho tends to jump to life but at least it works may be an underlying fault ECM I will get a friend to check that.
Old Sep 10, 2020 | 09:00 AM
Phil314's Avatar
Mr. Peabody: Sherman, set the WABAC machine to 2008!
Old Sep 10, 2020 | 09:15 AM
74demon's Avatar
Hey, this thread is 3 years newer than another he responded to. 5 more and he will be looking at current stuff.
rpmraper
Sep 2, 2011 09:27 PM
Matt40567
F2 Tech
Jun 7, 2011 05:21 PM
mr.z28
F2 Tech
Sep 13, 2010 09:00 AM
deadfred
Jul 29, 2010 11:45 PM
mj_wils1970
Jul 12, 2008 04:27 PM
