tach trouble!!!
Old Sep 18, 2008 | 02:03 PM
88stang's Avatar
Default tach trouble!!!
ibought a 94 f2about 3weeks ago and the tachometer doesnt work the needle just stays at zero. i thought maybe you guys would have some idea of what the problem could be.
Old Sep 18, 2008 | 02:30 PM
rray12288's Avatar
Default RE: tach trouble!!!
check the fuses
Old Sep 18, 2008 | 04:37 PM
Quickslick444's Avatar
Check the speedo cable to see if its spinning.
Old Sep 18, 2008 | 05:53 PM
pbrownw's Avatar
it won't have anything to do with the speedo cable, are the rest of your gauges/lights working properly?
Old Sep 18, 2008 | 06:28 PM
lonewolfcbr's Avatar
F2's use cable speedo's not tranny electronic ones....there is a cable(or should be) running from the right side(If your standing facing the bike) of the front tire, it mounts into a speedo gear that is attached to the front wheel, take a phillips screw driver and remove the cable from the gear, once you do twist the little gear with your thumb and pointer, see if the gauge moves...if it doesn't there is your problem.
FYI on F2's it's not electrical
Old Sep 18, 2008 | 06:43 PM
88stang's Avatar
i got another used gauge cluster and plugged it in but still got nothing, checked the fuses, and ill take a look at the speedo cable. anybody have any other suggestions? keep them coming.
Old Sep 18, 2008 | 06:59 PM
88stang's Avatar
i just checked the speedo cable and the speedo needle moves but the tach needle doesnt. im not sure but it looks elctronic
Old Sep 18, 2008 | 09:17 PM
pbrownw's Avatar
ORIGINAL: lonewolfcbr
he is asking about the tach, not the speedo
the tach is electric and completely independent of the speedo, in fact on my track bike the only gauge I have is the tach
check the connections for the gauges, but if everything else is working fine then I doubt that's it, you can check for power coming from the sensor into the gauges with the bike running, my manual is out in the garage, I'll check it tomorrow to see what color wires to check
Old Sep 18, 2008 | 10:36 PM
Hurricane rider's Avatar
I suspect that your tach is given its signal off either one of the coils, or out of the CDI, so check your connections at each, and find out if thats where the problem is.
Old Sep 19, 2008 | 11:24 AM
whoops lol i was thinking the speedo not the tach
