switched battery polarity
Old Jan 20, 2010 | 01:26 PM
cyrusyn's Avatar
I didn't charge the battery backward. Put the battery contacts on the bike wrong way.
How do you examine the relays?
Old Jan 20, 2010 | 06:37 PM
halffast1g's Avatar
no idea. my headlight never turned on by itself after that. I had to wire the headlight to the battery via a switch
Old Jan 21, 2010 | 01:06 AM
cyrusyn's Avatar
The bike now almost catches fire when I crank it. It is a matter of adjusting mixture. Spark is there as I tested with a spark tester. Checked ignition, headlight, gauge cluster, horn fuses and they are all fine. Horn works and I hear turn signal relay working. Only headlight is not turning on so I will see it with a new bulb. Hope the fan switch relay is fine.
Old Jan 21, 2010 | 05:24 PM
halffast1g's Avatar
my fan was still fine. I thought it blew the bulb as well so I went ahead and replaced the bulb, but the light didnt work. If you find where the relay is, or the problem, let me know because having it on a switch kinda sucks
Old Jan 23, 2010 | 01:06 AM
cyrusyn's Avatar
Light came on like 10 seconds after engine started.
Is yours G type? If so it has two relays on both sides of the front fairing stay.
Old Jan 23, 2010 | 02:52 AM
PlayfulGod's Avatar
the F2 have a fuel pump and if so is it running?
Old Jan 23, 2010 | 09:07 AM
Cyrusyn, Light came on like 10 seconds after engine started.
There are no relays that have anything to do with the headlight. The headlight gets power through these items in this order:
  1. Ignition Switch
  2. Fuse Block
  3. Starter Switch
  4. Dimmer Switch (high/Low beam)
  5. Headlight
If the fuse is good, then bad bulb, or bad contacts on switches or connetors.
Playful God, the F2 have a fuel pump and if so is it running?
No, there's no fuel pump on the F2.
Have you checked to see if maybe you've got the idle set just a little too low ? If you have spark, then your ICM is most likely ok as is the Ignition Pulse Generator.
Old Feb 9, 2010 | 07:44 PM
oxyg3ne's Avatar
the main fuse is the 30A ? there is only 1 ?
Old Feb 9, 2010 | 07:47 PM
Kuroshio's Avatar
Yes. The main fuse is a 30A fuse on the starter relay, not in the main fuse panel.
Old Feb 9, 2010 | 09:33 PM
oxyg3ne's Avatar
i did the same stupid mistake and found that the 30A was blowed.. now i only hope nothing else is fried .. probably not because the purpose of the fuse is to protect ;p
