Stuck Throttle
Old Apr 12, 2008 | 04:05 PM
spdbump36's Avatar
Default Stuck Throttle
Well i have a problem with the throttle cable. It is brand new but it isn't recoiling back so i get to have the pleasure of having cruise control when i really don't want it. I've checked the cables to and from the handle and there is no bind, The spring/part the cables are attached to seems to be sticky... Anything that would help to loosen??? Thanks
Kevin
Old Apr 12, 2008 | 04:20 PM
flashman's Avatar
Default RE: Stuck Throttle
Did you lube the cables?
Old Apr 12, 2008 | 09:54 PM
spdbump36's Avatar
Well i don't really know. Im kinda new to bikes so how would i or how would i know if they are lubed??
Old Apr 13, 2008 | 01:59 AM
flashman's Avatar
Well you would know if you put lube on the new cable which it doesnt sound like you did. I would make sure the cable had some grease and also ensure that there is no possible binding from the throttle handle itself. Check to make sure you have the handle seated properly inside the cutoff housing as well. Just ideas for you.
phishstyx
Dec 2, 2007 11:56 PM
grobleto
May 22, 2006 03:24 AM
ampakes
Sep 27, 2005 07:51 AM
2000cbr600
Jun 22, 2005 03:14 PM
TRBL600RR
Jun 14, 2005 11:12 PM
