squeaking noise?
Old May 30, 2008 | 04:36 AM
amig's Avatar
Default squeaking noise?
so im riding home and i notice that theres this squeaking noise my diagnosis so far is that its from the engine as when i put load(open the throttle) to the engine i hear it then when i let off it goes away?
any input would be nice
thanks
Old May 30, 2008 | 06:01 AM
woo545's Avatar
Default RE: squeaking noise?
You need to replace the squirrel with one that doesn't squeak.
Does the squeak speed up with the engine speed or with the ground speed? It's constant...fast slow...Does it happen in neutral? Does it sound like it's coming from the inside or outside of the engine? Is it more of a squeak than a whistle? Is there a mouse stuck in your air cleaner?
Old May 30, 2008 | 07:58 AM
MikeInCtown's Avatar
LOL< I've never heard of an engine squeak.
Check all the things that could normally make noise. Pivot points on the rear shock setup, front and rear brakes and front and rear bearings.
Old May 30, 2008 | 11:25 AM
FNQuickF2's Avatar
It might be a loose fan belt!
Seriously, I've never heard of anything like this...
Hmmm....
RB
Old May 30, 2008 | 10:50 PM
alejandrof2's Avatar
mmmmmmmm if it is squeaky mmmmmmm may be your bike is to clean??????????????????????//
never hear squeaking noise on my one but my one is dirty
dunno
Old May 30, 2008 | 10:57 PM
undercoverbrother's Avatar
something rubbing? prob tire on fender. squeaking from engine, as stated above , must be mice. lure them out with some cheese. good luck
Old May 31, 2008 | 12:31 AM
elmer's Avatar
I'm with Mike, check out your wheel bearings. get the tire off the ground and see if it has any side to side movement, that should clue you in to the condition of your wheel bearings. Check the brake calipers, maybe the condition of the pads. Might not hurt to pull the tank and take a peek at your air box. If some clown before you "modded" it by drilling holes in it or something that could possibly cause a squeak. While the tank is off might want to see if there's any points that are rubbing excessively or if you've got plastics that are rubbing against one another causing a squeak. Possibly something suspension related?
I'm just throwing everything that comes to mind, that way you stay busy trying to look at each suggestion made, and odds are, the more suggestions I make, the more likely one of them will be right. Haha, good luck to you.
rocflip
May 20, 2009 02:03 PM
pontyhufc
Apr 8, 2009 02:03 PM
ameersak
Nov 12, 2006 03:52 PM
Blue Fox
Sep 29, 2006 05:53 AM
RojerLockless
Nov 25, 2005 10:23 PM
