Single sided swing arm
Old Jul 1, 2009 | 02:06 PM
durty116's Avatar
Default Single sided swing arm
I was thinking of getting a single sided wing arm off of a 93 model vfr 750 and i was wondering if anyone has ever done this. They look like they would bolt up but you would probably have to fab a bracket on the frame to support he shock from the vfr 750. If anyone has input on knowing about this that would help thanks.
Old Jul 1, 2009 | 02:20 PM
azninferno's Avatar
do a search, this is a common swap. its going to be the next major thing im doing on my f2 fighter.
Old Jul 1, 2009 | 11:19 PM
deadsp0t's Avatar
Default swing!
while looking for ideas for my F2 i came across a site called vortexvw.com its a forum like this for vw. dude there had done that swap and detailed the install, he also had a gsxr tail and forks. i found thr thread by searching F2 street fighter on the new bing search engine, even if you already have the info you need should check this guys F2 its all one off and sweet as hell
Old Jul 2, 2009 | 10:42 AM
tundrafiend01's Avatar
A link would be helpful?
Were you referring to this: http://forums.vwvortex.com/zerothread?id=3957794
Old Jul 2, 2009 | 11:14 PM
deadsp0t's Avatar
Thumbs up cool
that would be the one! i thought about tryn to do the link but ive never done one before, ima head to the faqs and get the low down on that, ty for posting that link. so what do ya think? sweet huh?
Old Jul 3, 2009 | 08:54 AM
durty116's Avatar
That was beyond sweet that was ****** badass. I want to do this swap so damn bad. I didnt even know people had done this swap till i had seen a 93 vfr. once i seen that swingarm and that back wheel i was like holy **** i want lol.
Old Jul 3, 2009 | 10:07 AM
The first thing you're going to have to do is spend some time making measurements. The first measurement you need to make is the width of the F2 swingarm where it meets the frame. Based on this measurement, you can choose what arm to use.
VFR Pivot Widths:
Honda VFR750 (1990-93) - 242mm
Honda VFR750 (1994-97) - 227mm
You'll need to select whichever swingarm requires the least amount of modification to make it fit.
Once that's done, and you have the complete swingarm, you'll be in better shape to figure out the shock linkage.
yorkiejeff
F2 Tech
Aug 6, 2015 03:32 PM
kodeko
F2 Tech
May 18, 2011 09:50 PM
RojerLockless
May 4, 2011 02:15 PM
paddysasausage
Nov 20, 2007 12:07 PM
lococbrf2
Oct 17, 2007 05:33 PM
