RR help
Old Jun 7, 2013 | 04:24 AM
Artie Rivera's Avatar
Angry RR help
So I followed the write up and just completed all the connections with solder, dilectric grease, crimps, and heat shrink wrap. It looks nice and pretty. Then I stick the key in and turn to ON and nothing. No headlight, blinkers, starter, nada!
I checked the fuses up front and all seem to be in great condition. So now I'm stuck. I don't know what to check next. Any help please?
Old Jun 7, 2013 | 04:25 AM
update: I used the 2003 GSXR 1000 R&R
Old Jun 7, 2013 | 04:59 AM
MadHattr059's Avatar
There is a 30A fuse tucked under the seat in the starter relay housing.
You have to pull the connector to access it.
Ern
Old Jun 7, 2013 | 05:21 AM
duuuude. You rock... It's almost 3:30 AM over here and I've been pulling my hair out and re reading these threads. Too bad no stores open that sells a 30amp fuse...Thank you MadHater, you're a GURU!
Old Jun 7, 2013 | 12:47 PM
Just an update, got the new fuse this morning. Bike started right up and at idle I'm getting 14-14.5 volts. Looks like it is charging now! I'm taking the bike on a good 70 mile ride so we will see how it holds up. pretty excited!
Old Jun 7, 2013 | 03:01 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Old Jun 7, 2013 | 07:04 PM
Glad to be able to help.
If you haven't already, go through the rest of the harness, too.
Nothing like a solid-stable harness to keep that minty-fresh taste to a bike.
While you're at it...get a couple of spare fuses and
tape or stash them under the seat for "just-in-case".
Ern
Old Jun 7, 2013 | 07:12 PM
got back from the ride, bike was in perfect order! tonight i'm installing the new gas cap and ignition from Jeff!
